Hi all
Newly joined here, Looking for some help in regards to insulating suspended wooden floor in my lounge.
I was going to lift up the boards and install membrane and insulation method between the joists but the floorboards a pretty delicate now and tend to break easily after trying to lift a couple, also budget doesnt really allow to replace the whole floor etc. So ive decided against this solution
Another solution I found was some foil insulation which state that the product can be laid over the top of the floorboards and then sealed around the perimeter of the room with foil tape and then lay the finished floor over the top of this. Hence creating an airtight space. This will help with the draught's coming in from the gaps around the perimeter and also warm the space up
Now im worried about condensation appearing on the face of the insulation which will be against the floorboards. I checked the specs on some of these insulation foils and they say condensation doesn't occur because they are built up of multi layers but around 4-6mm in thickness but im still worried that over time there might be condensation occuring. I think the stack up is foil on the outer sides with a foam middle layer. Does this sound like it would work?
The other method would be to tape up the perimeter of the room with foil tape to close the gap between ends of the floorboards and the walls, But the areas of the floor close to the external wall where the air bricks are will still be cold
Has anyone had any experience with insulation floorboards from the top like this? I was thinking that I could coat the floorboards with a wood treatment to make them water proof and then have this kind of insulation on top. Would this work?
Hope you can help, Thanks
