Issue joining wire
27 Sep 2011
I have 4 cables
Call it
Left 1 (ie L1)
Left 2
Right 1 (ie R1
Right 2
L1 cable needs to join R1 cable
L2 cable needs to join R2 cable
To join the cables I am using Quickwire splitter
To join do I simply place L1 cable in the top left side of the splitter and R1 cable in the top right hand side of the splitter.
Then to join the remaining cables, do I simply place L2 cable in the bottom left side of the splitter and R2 cable in the bottom right hand side of the splitter.
The quickwire "splitter" used as you describe will join all four cables together.
If you want to connect the cable parts individually without connecting them to each other you will need two quickwire "splitters".
Are you looking at a different product to me? Surely ONE of these https://www.quickwire.co.uk/product/quickwire-splitter-junction-box/ will join the two wires together as required?
My concerns would be that the earth connection is also made, if present, that Line and Neutral are not crossed if they are present in the cable being joined and that the cable is a suitable size for the junction box.
I think we need a bit more detail about the cables being joined.
The OP said 4 cables and it reads as though they want to connect 2 pairs of cables independently so I'm with @plugwash
@pcaouolte : You are maybe calling cables wires, or perhaps the OP is calling wires cables. I'm also with you in that I think a bit more detail is needed.
It'd probably be cheaper and less confusing to use as many Wago/Ideal connectors as you need
Pay attention to the accessibility/serviceability requirements of any junctioning method you use
Are these mains cables on a household lighting circuit?
What colours are the wires?
Yes, this is from a lighting circuit.
The wire go to the switch which gave power and neutral at the switch.
Thank you.
I think I see where I've gone wrong now.
I need 2 splitters.
Because at the moment, I have connected
All of the brown COM with what would be the brown L1
Is there a difference between cable and wire?
I was under the impression the terms were used interchangeably when referring to domestics electrics.
You're right. I normally use wago 221's + wago box
But in this instance I needed a mantainance free junction box that has depth less than 30mm and the quick wire splitter was best option we came up with
When you say 4 cables, what's a "cable" to you? Is your "cable" brown/blue with one copper strand inside, or is it grey with more than one copper strand inside?
Sorry I should have been more clear in my initial post.
By cable I mean 2 core and earth, 1.5mm
The cables blue, brown and earth.
Theses cables are wired into my lighting switch
The switch has a neutral
I think these (or a junction block, even) would be cheaper and more obvious:
The 3 way ones are more useful, if you're buying a bulk of them and have other wiring to do; can get a hundred for 13 quid from tool station
Just bear in mind the amps ratings of some of these kinds of connectors, and check it's adequate for the work
