Those power saver adaptors
30 Dec 2018
Up North
No, not those, the plug in adaptors which turn one, or maybe two items on/off, when the main item stops drawing power....
I'm thinking to power my two bench grinders as the 'main' item, to switch a light on over the grinding bench. Do the adaptors actually consume power, when in standby?
Barely anything but I've had two just give up over the years and they have about a 0.5 second switch-on lag.
I gave it a try, to power up a light, when either of - two bench grinders, or a bench drill was in use. It worked sometimes, sometimes not, often it switched back off, once the motors were up to speed. It worked fine, if any two items were switched on. Obviously not enough current draw to be reliable.
What you require is a current rather than voltage operated relay.
I made my own using 24V AC relays, stripped the enamelled wire from the coil and replaced with some thick enough to take the motor current, adding enough turns to operate reliably.
EDIT: It occurs to me I may have posted about these before
Or you could wire the light after the grinder switch.
I have one issued to my dad by British Gas, it was designed to monitor the computer power being used, and turn on printer, modem, and other devices on/off with the PC, today with wireless printers and broad band and laptops using so little, it is really pointless, and I have been using it as normal extension lead for years. There is some button on the side that says mode, and a light which says status, and a 3.5 mm jack but I have never had the instructions for it.
Yep! Long ago, I did something similar....
I wanted to sense, and sound an alarm, when any of the PIR lights on a circuit was triggered. I simply would a few turns of the supply to the PIR's, around a transformer, rectified one of the outputs of the transformer, then connected Piezo sounder. It worked fine, for years.
No, I don't want to delve into the machinery. I'll try something similar to the above, but feeding a relay, rather than a Piezo sounder.
Does your grinder have start/stop buttons and contactor?
In not; leave switched on and use an additional (external) switch.
Two bench grinders and a bench drill. The grinders have simple on/off switches, drill has strat/stop buttons. I was rather hoping to set it up, so that if any one of them was turned on, it would also switch the light on/off, over them. They are in a bit of a dark corner, and I would tend to leave the light on, perhaps for days, until I need to go back in there.
So nothing particularly powerful. Is my picture obvious?
If not the bit of enamelled wire coming out of the left of the clear plastic is a few turns of approx 1mm in place of the original thousands of very thin wire and exits the other side. I deliberately didn't try to use the original pins due to the high current of the pumps.
In my case I purchased those relay in trays of 50 so 'stock' item.
Cost naff all, free to run and simple.
Otherwise use a current clamp switch but most are solid state 'contacts' and limited to ELV.
"Power Saver" adaptors seem to be a more "politically correct" name for that which has been called "Master/Slave" controls (PowerBoards etc.)
(Replacement names for "Master" include 'default', 'primary', 'controller', 'root', 'initiator', 'leader', 'director', 'manager'; and for "Slave": 'performer', 'worker', 'peripheral', 'responder', 'device', 'replica', 'satellite', and 'secondary'. - https://en.wikipedia.org/wiki/Master/slave_(technology) )
A "commercial module" which may suit your application is the Kemo M103N - Master/Slave switch 230 V/ AC
(https://www.kemo-electronic.de/en/T...3N-Master-Slave-switch-230-V-AC-400-V-AC-.php )
This "module" consumes <0.5W on standby - probably, for the Extra Low voltage supply for the "sensor" and the relay.
Then, there is https://www.ahoku.com.tw/en/product/Smart-Power-Management_CA-U609MS.html
All such "sensors" are likely to have some "standby" load.
It is my understanding that devices such as TVs, computers, microwave ovens etc are now required to have standby loads of less than 1 W.
This device seems to "comply" with that requirement.
How many devices do you have on "standby" around your premises?
The method I described above, involves no standby load at all.
No problem with that, if they are in fairly regular use, but this comes under the 'quite rare use', so difficult to justify.
Lots of slight loads, hence why I don't want to increase it. My partner brought with her an old TV, as a better size for the occasional use in the kitchen. I got around to checking it's standby consumption yesterday and was relieved to see it only consumed 0.4w - I was expecting it to be much more. .
Just as Harry says: The method I describe with a current relay (modified AC relay) also has zero standby load and no additional in use load either.
