- Joined
- 31 Aug 2015
- Messages
- 64
- Reaction score
- 1
- Country
Description of works: Worcester External Heatslave II 25/32
Labour and materials: £8,990.09 (including VAT) including Engineer’s discount for Health Check.
- Lay dust sheets to all working areas. Discuss programme and protect areas to clients’ request.
- Take out the existing external regular boiler and clear away.
- Carefully take out the existing hot water tank, cold water tank and all associated redundant pipework and clear away (asbestos roof tanks will not be removed, they will be double wrapped in polythene and lift in the loft).
- Supply and install a Worcester Bosch External Heatslave II 25/32 Oil Combination boiler, located in the existing position with a standard flue system.
- Supply and install new pipework from airing cupboard to be installed and lagged externally and connected to new boiler (please note these will require additional ‘boxing in’ and protection from external elements to prevent from freezing).
- Supply and install a condense discharge pipe to connect to the nearest waste pipe, drain or soak away.
- Supply and install a ‘lime fighter’ in line scale reducer.
- Supply and install an auto bypass valve.
- Supply and install a Google Nest heating control.
- Take out any redundant pipework and supply and install all necessary pipework. Insulate pipework in unheated spaces.
- Carry out a full ‘powerflush’ of your system. This involves carrying out a thorough clean of your system with a powerflush machine. Each radiator will be cleaned individually, in situ, with the water circulated in both directions. The entire system is flushed and drained and refilled with clean water and a system corrosion inhibitor.
- Carry out all necessary electrical work and issue a minor works certificate. Register any qualifying works with NICEIC, a ‘Part P’ certificate will be sent, if necessary, to you directly from your local building control office (required if you sell your home).
- Supply and install a fire valve to the new boiler.
- Carry out a commission of the oil boiler, issue an OFTEC commission certificate, register the installation so that you receive the ‘letter of compliance’ from your local building control office (this is required if you sell the property). Register all manufacturers guarantees and installation manuals.
- Attend property with holding tank.
- Remove any oil left in old tank.
- Installation only of customer supplied oil tank.
- Customer to supply new base for oil tank.
- Pump over any oil from holding tank.
- Purge oil line through to boiler.
- Remove all rubbish and leave clean and tidy.
- Subject to survey and remeasurement.
