I've fitted a few windows myself and not had any issues but notice on the one I'm doing now that there is a gap between the black gasket and the glass. Its tight in the corners, but as you go along, the gap gets bigger to about 2mm in the middle. This is a bigger window than the others, so the lengths of beading are longer, but I'm sure there should be no gaps or what's the point of the gasket? I can push the beading and see the gap close then open when I release.
It is the same on all the longer lengths of beading, but not the shorter top and bottom beading of the opener.
The affected.lengths are 30" to 50". I wondered if the beading was too long and bowing out, but refitting shorter beading made no difference.
There's no gap on the outside, so it's just the beading that is affected. Should I be worried?
