Hi.
I have a property with a traditional gravity-fed system, with bathroom taps running off an old salamander pump with 22mm pipe.
The electric shower runs from mains and pressure/flow is abysmal (we’re talking less than 3 l/m and something around 0.2 bar). I was hoping to upgrade the pump (which is noisy) to an ST Monsoon and also have this feed the shower. Before anyone asks, I've done all possible checks on the mains plumbing, had Thames Water out etc. It's 1.6 bar at ground floor (so TW are happy) and the split-level flat is 2nd/3rd.
The shower is run off 15mm pipe (which runs through the cupboard that the pump is in). I’m trying to work out if that is likely to be a big problem? Especially if the taps are 22 and the shower is 15? There’s potential to make this join the shower piping in the bathroom itself, as close to the shower as possible, so it could only be a couple of meters vertical into the back of the shower that would be 15mm.
I can’t afford to pull the bathroom apart to change the pipe to the shower so if it’s not viable then it seems I’d need to have a separate pump (like ST Showermate which appears to have 15mm connections) for the shower? But having 2 separate pumps (and, I guess, needing two separate feeds from the CWS - not sure how/where they’d split?) is not preferred. Not to mention I still want to replace the existing noisy pump...
