D
Deleted member 307320
Probably worth mentioning that there's no sign of this issue elsewhere in the property
Do they dim for a split second or stay dim?
Stay dim, get progressively dimmer when load is added to the kitchen ring
Have you anything like a plug in volt meter, so MiL could easily report what she sees the voltage doing, when the lights dim?
Thinking aloud ....MFT...
Could you perhaps clarify exactly what you mean by that? Are you saying that (as one might expect) the lights only dim when a high load is applied to one particular circuit, or what?Probably worth mentioning that there's no sign of this issue elsewhere in the property
Thanks for clarifying. Does that mean that the kitchen lights are on a different circuit from the other lights in the house? If do,is it perhaps possible that the kitchen lights circuit and the circuit on which large loads dim the lights have something in common - e.g. protected by the same RCD on a dual-RCD CU?The dimming only seems to affect the kitchen lights, none elsewhere in the house.
That obviously potentially moves the goalposts, and maybe adds more weight to erics suggestion of a problem with the incoming neutral.It also seems to be affected by something outside of the property, it was particularly bad yesterday and there wasn't much load on the CU. Assuming it was from the neighbours as they share the service head...
I'm reassured to hear that it's not only me who is guilty of such oversightsI was going to check it out tonight, but I got home and realised I'd forgotten my MFT![]()
