    Dismiss Notice
Socket suddenly drops voltage
Discussion in 'Electrics UK' started by mr rob, 15 Sep 2019.
  1. mr rob
    mr rob
    17 Jun 2015
    49
    Thanks Received:
    Country:
    The under unit led lights in our kitchen dimmed recently. The strips were not faulty and were tested elsewhere.
    Turns out the power at the junction box of this set is not 240v but around 133v
    what could have caused this, is there a fix?
  2. Sponsored Links
  3. conny
    conny
    30 Jun 2008
    11,033
    Thanks Received:
    299
    Suffolk
    Country:
    With power isolated check all terminals and wires are tightened down properly.
    If it's still low then further investigation is necessary.
  4. mr rob
    mr rob
    17 Jun 2015
    49
    Thanks Received:
    Country:
    yeah opened the junction box and rescrewed all terminals. its the white circular junction box that feeds the lights.
  5. EddieM
    EddieM
    15 Feb 2009
    7,481
    Thanks Received:
    306
    Country:
    wired in series perhaps ?
  6. ericmark
    ericmark
    27 Jan 2008
    14,606
    Thanks Received:
    1,299
    Llanfair Caereinion, Nr Welshpool
    Country:
    I have seen this where some one has mistaken a switched line for a neutral so either run in series or off. And where the other lamp was a large one it seemed to work, changing other lamp and then large volt drop, so question is have you swapped a tungsten bulb for a LED at the same time as this happened?
  7. Sponsored Links
  8. mr rob
    mr rob
    17 Jun 2015
    49
    Thanks Received:
    Country:
    nothing was changed, no led strips swapped out, no wiring. these were led strips powered direct from mains.
  9. 333rocky333
    333rocky333
    12 Jan 2008
    7,376
    Thanks Received:
    707
    Essex
    Country:
    Where did you measure 133 volts
    Personally i would measure
    L To E
    L To N
    N to E
  10. mattylad
    mattylad
    27 Apr 2008
    6,313
    Thanks Received:
    362
    Country:
    Where does this junction box get it's supply from?
  11. mr rob
    mr rob
    17 Jun 2015
    49
    Thanks Received:
    Country:
    turns out was the switch - has fused with dust or something
    • Thanks Thanks x 1
  12. FrodoOne
    FrodoOne
    20 Feb 2017
    330
    Thanks Received:
    35
    Melbourne, Australia
    Country:
    Australia
    If the switched had been "fused" it would have been "fused together" (i.e. Short circuited)
    However, it may have been "clogged with dust", and hence, partially "open circuit", especially to a low current load.
    No doubt, by now you will have cleaned the switch contacts concerned
    with a suitable "electrical" cleaning spray or
    by removing the switch and washing with methylated spirit (denatured alcohol) and then reinstalling it or
    you will have replaced the switch concerned.
Loading...
Share This Page
