I discovered a small leak inside on a ceiling next to the wall where the gutter is.
Got someone to look at it and they showed me that there’s a hole in the gutter (hopefully you can see it on the right corner area). It was clearly leaking water when they tested it. I’m also showing a photo of the other side of the gutter.
They cleaned the gutter as it was full of moss.
They say that the whole gutter needs replacing because it’s an old one-piece type. Otherwise they’d just fix the union area on a new style gutter.
The issue I have is that the ceiling leak was on the side of the gutter that looks fine. So could it have been the moss that was causing the ceiling issue?
They also said the floor above (where the roof and upper gutter is) is probably full of moss but it’s too high to come and clean without a taller ladder. Couldn’t that blockage have caused the ceiling leak from water running down?
Lastly could I try and get the hole that has been identified on the lower gutter blocked up without replacing the whole gutter?
I’ll probably sell the place next year so just want to avoid paying more than I need to now.
