I have 16 rads in my house. Got work done a few years ago and moved the rad with some plastic pipe. The plastic pipe was connected where the rad was, and instead of drilling holes through the joist. The pipes where brought over the joist in the void area then back into the same room on the same side, same wall only now on the left side instead of right.
To this day, the rad has never heated up. I was thinking it was maybe an air lock. Tonight I connected a flexi hose to the rad valve on one side. Opened it, let the water run through it for a few mins to see if this pipe was air locked. Water was roasting. I did this again in the other side rad valve. Roasting the water was like the other side.
Put rad back on, opened the air bleed valve. Let the water out. Rad mildly heated up then went cold!
I'm baffled at what's going on. All that was done was the same size pipe connected to where old location was. Brought to new location with lagging. New rad valves and now theres no heat at all to the rad.
