- Joined
- 14 Nov 2023
- Messages
- 2
- Reaction score
- 0
- Country
Hi everyone, I've been trying to understand this heating loop for a while and wanted to check if my understanding is missing anything.
Context: an Ecotec 418 set up in heating mode in attic. A single pipe runs down to the flat, where it splits into two (Y configuration), with one pipe charging an unvented cylinder, and one pipe going to radiators. The pipes join up again and travel back to the attic to the boiler. Each of the two branches at the Y-split has it's own zone valve controlled by the heating logic.
There is an external pump on the return pipe in the attic, controlled by the boiler. There is also a bypass valve + pipe, but this forms a bypass right between in the inlet and outlet of the boiler itself, and the "bypass circuit" does not include this external pump.
My understanding is thus that if both of the Y-split zone valves are closed, then no matter how hard the pump spins, there will be no water flowing around the bypass loop because the pump is outside this loop. Thus the boiler overheats and shuts down, and this is indeed what we were experiencing. We implemented a quick fix a while back - for the cylinder charging zone valve to always be open, so that the boiler can gracefully turn off instead with proper pump overrun through the cylinder if there is no radiator heat demand.
However I suspect this is causing a lot of inefficiency as it means water is constantly circulating all the way down from the attic whenever the boiler is checking for heat demand, even if the cylinder is hot enough. Likewise, the boiler is always "drip feeding" heat into the cylinder and thus endlessly cycling.
Mainly two questions:
1) Is it correct that the Ecotec 418 does not have an internal pump, and thus a bypass loop around the boiler itself is useless/likely incorrectly installed)
2) Assuming (1), is the only option to fix this to reroute the bypass to include the pump?
