I'm in the process of adding plasterboard to a ceiling before a skim coat.
How important is it to get these flush? there is a small gap of maybe 3mm between a couple of these?
Also when jointing two plasterboards some of the boards cannot be fixed with screws along the joint line due to lack of available joists - how much does this matter? Would tape and skim do the trick or just crack over time? Is it better to get these fixed somehow? Is it possible to use a glue behind to stick to the celotex insulation instead?
Many thanks
Many thanks
