Hi guys,
Sorry if this topic has been already discussed (and I've certainly seen it several times) but even after reading different threads I can't get my boiler to work.
Here is the situation:
Hot water operation is fine, all other relevant functions (i.e. warmstart, etc) with HW system are working.
Heating operation only works when forced manually by pressing "+" and "-" simultanously (in SF.h mode).
The status code I'm getting is S.30 so no heating demand.
Boiler is connected to UFH heating manifold with thermostat on the pipe. In SF.h I can heat the pipes easily.
Things I've done so far:
- checked the manual and disconnected any external thermostats (now pins 3 and 4 are linked).
- both 3 and 4 have power while 5 remains neutral
- checked other boiler operations (like HW and SFH) all works ok
- checked the temperature dial setting for heating and turned it max right (open)
Now as I would really like my boiler to be a little bit more automatic and heat my radiators up without me (by doing so in SFh mode) I'm really keen to get this one down.
Did anyone seen an issue like this or can point at something I'm doing wrong?
I would really appreciate your help and advice.
