Evening,
Our system: glow worm ultracom 18hxi boiler, unvented under pressure hot water tank (possibly aquasystem?), a mix of microbore copper pipes and modern copper pipes. 10 radiators.
We have had issues for the past year, British Gas have said it is because there is restricted flow. Husband got the system working by down rating to 9kW so that it fires up, drops to one flame, runs at one flame for about 13 minutes then fires at 3 flames up to 70°C, where is sits happily.
Hot water does similar, fires up slowly and runs at 70° until the return gets to a certain temp, then it short cycles for the rest of the hot water programme time.
Today we had the heating drained down for a new radiator install (involving moving pipes). On first fire up, the boiler was unhappy and started banging loudly, going past 70° then shutting off. It now fires up and shuts off, then comes back on at one flame. It sits at one flame, currently at 54° and not getting any hotter.
If I turn the heating off and put it to hot water, it just short cycles continuously, firing up and switching off and continue to shoot up to 85° before falling back down.
If I put the heating and hot water on together, it fires up and runs at 3 flames happily, but only at about 64°.
I've been doing lots of looking and I am not sure if it is air in the system, sludge, a knackered heat exchange or what!
Any advice?
Any advice?
