I plan to put in a deeper bath. Which holds more water. Up to 90 gallons.
The purpose of a deeper bath is so I can have a nice wallow, which I can't in the present one.
So the standard cylinder 36" x 18" that holds around 25 gallons will no longer be large enough. Or will it...?
I could put a taller cylinder in the airing cupbd, but not a wider one.
Would I get more hot water from a dual immersion cylinder the same size? The Gledhill 900 for example.
We are on Economy 7.
I know that usually the bottom immersion is switched overnight and the upper one used for topping up, but I could use it the other way and could switch both immersions on if taking a bath, and just the top one otherwise.
The cylinder only feeds one basin and the bath, and the bath isn't used every day. The kitchen has a separate heater and we have an electric shower.
What do you think?
What do you think?
