Hi. We have an old system gas boiler that is working well and regularly serviced. We have had a Hive system installed last winter. We have 14 radiators attached not all on at the same time. We noticed the bathroom ensuite radiator would be slightly on when the heating was on water only. The plumber replaced the 3 way valve, the actuator and the hot tank thermostat the CH worked for a few days and then the hot water would work but not the CH. The only time the CH would work was when the hot water was on. The electrician came out and replaced the actuator. That has lasted a few days. Now if we want the CH On we have to have the water on. When the water heats the tank to the target temperature the CH and the hot water switches off. Please can you shed any light onto why this keeps happening?
