Water running down wall from soil pipe
9 Jan 2018
Hi All,
As the title says, I have rain water running down brick work from where a soil pipe enters our house. Is there anything I can fasten onto the bend to take the water to the ground or any other suggestions? The attached picture shows the problem
Thanks all
Stand back and take a wider pic of the entire wall, all the way up to the roof and down to the ground.
When was this pipe installed, and why?
The waste pipe runs internally from ground level to first floor but then had to go externally due to internal fit out. It’s on a new build
Where is the water coming from
The rain catches on the pipe, runs down it and onto the brick work. I wondered if there was something that could be attached that would let the water run down or drip to the ground, away from the brickwork
