Hi. I'm having the bathroom redone and want to install a better shower. We have a basic mixer one and the pressure is quite poor.
Our hot water is from a tank in the bathroom. I think it's a pressurised closed system. There is the main hot water tank with a backup immersion heater, and the boiler with a separate smaller tank labelled "expansion vessel" on the cold water feed. There is a pressure gauge that reads 2.2 bar, and a couple of valves we can open to top it up if the pressure falls.
Cold water is direct from the mains, the tank was removed.
If I'm understanding this right, I need something like a Trevi Boost, but those doesn't seem to be available when I search for them. Is it right that you can't control the temperature at the shower with those?
I see there are various other pumps available, but they seem to be designed for gravity fed systems. Can't have a power shower because they can't be connected to the mains. Is there anything else? Thanks.
