If it's on 10mm feeds then that's a big rad, is it one of the rads that doesn't heat up properly?Is that bad
Useful flow calculator https://heatpumps.co.uk/pressure+flow/simulator.html
Yup, much thicker walls with plastic, that and the inserts drop the effective ID to around 7mm wherever they are usedJust seen this. 10mm plastic only has just over half the internal cross section of copper! I'd no idea.
The main resistance to/from a rad is at the valvesadd much resistance
Completely agree, the issue with this though is the tradesman hasn't completed the work IMO. The work is only completed when everything is fitted and finished and it all works as designed. If it doesn't then they shouldn't get paid. I always run the system up as per design and get the client to check everything, even then though, if it then has an issue then the work is guaranteed and I'll be back to sort it.I always work on the principle of if the work has been done why should the tradesman have to wait around for their money
Your boiler probably has a setting which adjusts the heat input for the central heating. Has that been checked?
