- Joined
- 22 Aug 2006
- Messages
- 7,060
- Reaction score
- 1,178
- Country
Oh.
Size down. man.
I took nothing in the UK - no catalyst knowledge, sludgy performance, lousy spreads. Sometimes something is grabbable. You can usually range trade something, or the odd breakout but I don't spend time on it after the open, as a rule.
Well, I feel a bit bad, now. Hopefully one day TTV will do well for you, like it did for me today.
I was cross with TTV because all except Baba was wrong up front so I faffed around with COIN which was going ok, then on the show someone mentioned HOLO. It was already up a lot when I tried a bit, then more, and more, then all in until I hit the platform limit. Finger was hovering over the close button all day and I swallowed hard a couple of times, finally hitting it right at 9.
Completely bloody exhausting. That was a meaningful day. I can't quite believe it. It went higher in after market, I believe.
If you're feeling down, don't look at the HOLO number for the day. If you're not, you already know the CFD multiple is 5 and what the pot is, add a few % x5 on the pot, from Coin..
The leveraged ETPs are ok when you're pretty sure the trend will go on so at the mo I'm "saving" into FANG3, NVD3 and ARM3. I dip into qqq5 and keep India3, which, usefully, isn't any FAANG stocks, but it did well recently.
I'll look at a couple of your trades
Size down. man.
