Hello everyone,
I'm seeking some advice for my upcoming bathroom renovation, which will be my first. While I consider myself moderately skilled in DIY, I could use some guidance and reassurance regarding my plans to renovate our ensuite.
Since moving in six weeks ago, we're now onto our sixth leak, the most recent occurring in our ensuite. Initially, I suspected it was due to waste water pipe but upon closer inspection, it seems there was a previous leak closer to the mixer tap, leading to rot in the studwall.
My intention is to keep the bathroom fixtures in their current positions, except for the shower waste, for which we plan to install a low-profile shower tray and so will move accordingly. Here's my proposed plan of action:
1. Remove and replace the floorboard, opting for either chipboard or plywood. Is there a recommended for a low-profile shower tray? I've heard plywood is better?
2. Re-route necessary shower waste pipes to accommodate the new waste trap location.
3. Treat affected areas with Ronseal Wood Rot Hardener and install new 2x4 timber alongside the existing stud walls. Although the damage looks severe in photos, I'm confident in securing a solid fixture to the old studs.
However, I'm a bit uncertain about the next step. I'm torn between tiling and using shower panels (such as Multipanel), with the latter seeming more appealing due to recent leak issues.
Regardless of the choice, I'll need to repair the walls to the left and right of the mixer tap. These walls consist of brick and plaster (?) on one side and breeze block and plaster (?) on the other. For the wall with the mixer tap, my plan was to install hardie tile backer unless others suggest otherwise.
My main question is how to effectively repair the walls on the left and right sides. Should I:
1) Install the tile backer first on the mixer wall
2) Remove the old tile adhesive from the left and right wall, and then use Gyproc 60 to fill in any significant gaps?
I would use tile backer on the left and right wall - but this would overhang the door frame, and furthermore - i'm looking to either tile or shower panel the entire room - and so this would create a lip.
Any advice or guidance would be greatly appreciated!
