Leaning Post - Concrete Repair Spur Vs Steel Repair Spur
This one seems pretty easy - unless it's stainless steel, it will rust. Concrete will not rust. Concrete can last hundreds of years.
The Fencemate is made from 2.5mm hot-dip galvanised cold-rolled steel.
According to manufacturer you can expect at least 15 years from the material
It is lightweight, easier to maneuver and less digging but won't last as long as concrete one.
The metal one does not support the post and resist lean anywhere near as well as a concrete post.
I have used both
And the steel ones have rusted away to wafer-thin scrap.
I do however use steel sockets for my shed posts
They are set on concrete pads
Above ground level
Secured with stainless bolts
Inside the shed so protected from rain
And treated with multiple coats of protective paint before assembly
The shed is a downward dead weight, it does not have sideways forces from wind trying to blow it over.
Another tip
If you concrete in the support, and leave it a couple of days to harden (a week is better) before bolting the old wooden post to it, the support will not move and loosen in the fresh mix, and will stay upright. Saw off the rotten wood a couple of inches above ground to prevent it soaking up more damp.
I use stainless studding, nuts and penny washers because I am in a coastal location and suffer accelerated rusting outdoors.
Concrete post purchased.
Another tip
Brilliant - Many thanks for the tip John.
