- Joined
- 10 Aug 2015
- Messages
- 42
- Reaction score
- 0
- Country
Hi all,
I am in the process of doing some once-in-a-generation changes to a property and I've got something I'd like to achieve but I don't know if it's feasible.
The property is large and consists of two separate houses shared by members of the same family. There's also some fairly large outbuildings that are fed off of one of those properties in a way that was probably fine a generation ago but is a bit dodgy now. Both properties currently have overhead single phase supplies.
My ambitions are:
Part 1: I would like to pull the two single phase supplies out and replace them with a single underground 3 phase supply in to one of the outbuildings. I'd then like to run an underground supply to each of the two houses and also tap off power directly to run the outbuildings. I've spoken to the DNO and received a quote for this work (as far as the termination of the 3 phase in the outbuildings) and that's all fine.
Part 2: Ideally I would to preserve the ability to run 3 phase equipment in the outbuildings at a later date, and I'd also like to have the option to introduce solar and/or battery storage and have a single installation able to satisfy the whole site.
My electrician is saying that part 1 is fine but part 2 can't really be done at the same time. Is he right or is there anything he might not have thought of? Not that he's not good, but I think I'm asking for something a bit unusual here so thought it'd be worth asking.
My ambitions are:
