Opening a roller blind mechanism
27 Mar 2011
Buckinghamshire
I wish to replace the chain in my 38mm blind roller for a continous chain type. I've taken off the clutch/mechanism on the side but I cannot figure out how to do it. It should be as easy as this YouTube video shows but the two prongs that the video shows can be pinched, on my one it does not move at all. There is a round hollow cylinder which looks like it is a pin that prevents it but it won't budge.
Is anyone able to help me to work out how I do this? I'm attaching photos of the mechanism:
Blind mechanism 1.jpgBlind mechanism 2.jpgBlind mechanism 3.jpgBlind mechanism 4.jpgBlind mechanism 5.jpgBlind mechanism 6.jpg
(Alternatively, I've seen replacement 38mm clutches that seem to allow far easier disassembly such as this one: https://www.amazon.co.uk/hocadon-Bracket-Fittings-Curtain-Brackets/dp/B09HZ377V3 )
The video is for a different blind, on yours you would need to remove the pin possibly destroying it. Why are you attempting such a pointless task? Continuous chains are not longer used due to the choking hazard it presents. Replacement gears are widely available but again for use with safety chains.
I'll try to be careful not to choke on it then :LOL:
It'd be nice if people are able to help without judgy comments like:
"What's wrong with the blind?"
"Why are you attempting such a pointless task?"
If there is anyone who can help without judgement then that would be very much appreciated.
I'm happy to drill out the pin if there's no easy way to remove it.
The hazard is to small children but I guess you qualify .Good luck with your pointless task .
I'm well aware of the choking hazard to children on blind cords but I don't feel the need to justify why this isn't an issue in my setup.
It's a bit pointless you bothering to post if you're not going to be helpful. Would you rather save your time by just not bothering to post at all.
I'll take my request to some other forum that will be more helpful.
So is the problem that the drop of the blind is a longer length than the chain that has come with the bind, as if that is the case then I would suggest you have been supplied with the wrong fitting and need one with a longer chain.
For the second time, there is nothing wrong with the blind. I want to fit a contininous bead chain without it having a join. I can fit it to the existing clutch mechanism if I can get access to the cog, but I can't figure it out hence this post.
I would give up to make sense of the noob.
Thanks for the valuable lesson everyone: if you need helpful and non-judgemental advice, diynot.com is not the place to post.
