How much plaster to take off after rising damp?
29 Jun 2023
125 year old Victorian terrace and had penetrating damp on external wall, cracked soil pipe now fixed, and damp/ salts coming through a small amount into internal lounge wall. Stripped paint off but salts still appearing through plaster.
I have now chipped away the smalls section of plaster expecting to see brick but I have come across a slab of concrete on one side and some black crumbly stuff on the other. Having looked behind the black stuff, I can see the red brick about 1.5inches back.
In order to fully let that part of the wall dry out, can I let it dry out as is now the contimainted plaster has gone for a few months and then re-plaster with salt resistant plaster?
Or do I need to fully strip it back to brick, take concrete and black stuff off, which will create a gigantic hole to then have to fill back in before plastering?
Once damp problem is resolved it can take many months for salts to stop leaching out .
So is it just worth leaving it as it for a few months and then re-plaster once salts stop or do I need to strip it the other 1.5 inches back to brick which I really don't want to do to let it dry out?
Also, would I use regular plaster to repair the whole or could I use tanking slurry as well to make that part of the wall waterproof or would I just be pushing the issue elsewhere?
It's not very deep, so Joint Cement will do it.
Fill once, slightly recessed, then a final thin skim, pressed very hard. This is a good way to fill and cover any cracks or blemishes that might occur.
Never overfill above your intended finished surface. If you do, shave it off before it sets hard.
