DPC Problem
14 Jul 2024
My builder has retrofitted a physical dpc in internal walls but has used 100 mm dpc over old bricks which are 110mm wide. 5 mm at each side of brick not covered.
Will this still allow damp to rise? If so, what are the solutions? My builder won't redo it.
Thanks for any advice.
The builder will have to redo or rake out the mortar back to expose the dpc without damaging the dpc, then never bridge that gap with wood, plaster, brick, gravel, stone etc..
Doesn't sound to be a competent builder.
Damp falls , does not rise .
Why have i got a damp patch in a single skin internal wall where both sides are exposed, there are no leaks above ground and there's damp on both sides up to about 300mm either side then?
I don’t know your property so difficult to know with zero information .
Damp can rise 1.2m, dpc should never be breached. Ignore foxhole.
Correct! The damp course should never be covered/incontact with anything which is absorbent, such as cement or plaster. If the DPC is to be behind skirting boards, then the plaster behind the skirt, needs to be removed.
How did he do that? Cutting a slot along the wall through a mortar joint?
Where do you think the water is coming from? A leaking pipe in the floor?
Post some photos, of the entire wall, both sides, showing the shape of the damp patch.
Is it a concrete floor?
No case of rising damp has ever been proven , £10,000 reward for proof still remains unclaimed.
Anything hygroscopic, such as plaster, or timber, in contact with moisture, below a DPC, and bridging it, can allow that moisture to spread up hygroscopic materials on that wall, such as the wall plaster. Bridging of the DPC, being the most common cause. Having said that, most damp and mould is not due to rising damp, but to other causes. Blaming DPC failure, is a favorite MO of many companies, claiming to provide an expensive fix for DPC failure.
