The EV should be teed in before the pump which should give a higher system pressure and less chance of air ingress.Hi all,
Ok, heres a system sketch from what I can see.
Hope it makes sense, Im no Picasso!
The boiler, magnaclean and PV are all in the loft, approx 3M above ground level.
The pump is a Grundfoss UPS2. Ive checked the compression fittings, all are good and tight. Pump flow is pointing the correct way.
The cold water feed tank was literally 20cm higher than the boiler when removed and pressurising the system.
Also, the boiler MIs show a AAV, I would definity check or gegt it checked out in case its pulling air in there, the cap on these is generally closed after initial fill, it maybe accessible from the boiler top but unlikely.
