32 mm compression on 35mm chrome
Just another question. I'm thinking of cutting the bend off the crome going underfloor so can put a 90 crome on. Be able to disconnect for tiler then.
I can see there are crome conpression but are the other crome 90 pushfit ?
If that chrome is 35mm/40mm then if you really have to cut it - as suggested try not to - then use McAlpine's Chrome brass fittings - they are by far the best quality you can get, not cheap tho.
