D
Deleted member 318094
Hi everyone.
We had a 'carpenter' make a gate and fit it.
He insisted on fitting it while we were out. Check out the installation of the post to the rotten fence. This was later changed to rawl plugs on a quick return visit following a message from a concerned neighbour. The hammering of the plugs has shattered the post internally and it has burst through the other side
I'm left to clean up this mess.
Has he made the gate upside down with regards to the mitre? Its not doing anything like that is it?
pins and glue used throughout.
i'm switching to 24" heavy duty T hinges from 12" which are already distorted and it has a jockey wheel (which was fitted wonky also).
i've since coach bolted through the post with spreader plate on the other side for stability.
Thoughts
Thoughts
