- Joined
- 11 Jun 2016
- Messages
- 373
- Reaction score
- 18
- Country
Best way to sort out issue.
I was lightly sanding down existing paint work to redecorate, all good until the paint on the front on the chimney breast started peeling away from the layer underneath. The chimney breast is in use & i assume it has a liner for the gas fire.
I've used a scraper but it's just taking off more, also sanding with 600 grit paper & the same outcome.
Is it just a matter continuing to do what i am doing to it stops or is there a faster way to sort it out. I've read it's best to use primer afterwards. I have a tin of Zinser coverstain, would that suffice. Many thanks for reading.
