- Joined
- 27 Jan 2008
- Messages
- 29,428
- Reaction score
- 3,615
- Location
- Country
I have a small battery 3.2 kWh, solar panels, and a split tariff. In hind sight the battery and split tariff are it seems paying for themselves, but due to lack of export payment, the solar panels are not really doing that well.
Been in around one year now, so solar has produced 5000 kWh, I have used about the same, but exported 2500 kWh and imported 3000 kWh in rounded figures, from software
The smart meter was not fitted until January and did not get duel tariff until February, it was noted that solar in Winter would not recharge the battery some days, so all solar produced in winter is in the main used, but money wise it is the recharging of battery over night which saves the most money, this
from yesterday is typical, but this
where battery runs out before the low rate returns is getting more frequent as Winter gets closer, the options on my system is 1 to 4 batteries each battery being 3.2 kWh and the batteries are not cheap, well over £1000 for the battery.
We are told batteries have a life, so likely will last 7 to 10 years, but battery one has also given us UPS for freezers and central heating, so no question battery one is well worth it, where it is less cut and dried, is battery two, and our use of electric will change how it helps.
If we had a cooked dinner at midday and a cold tea time meal that would save electric, and if I adjusted when the battery stops charging in the summer, so that droop in state of charge (SOC) in the morning got closer to the 10% cut off, that would also save money. But changing life style to suit the solar production seems wrong, we do washing before 4 pm or after 1 am so either solar or off peak used, so 4 pm to 1 am no washing is done, but other things have not changed.
Our electric bill dropped when panels were fitted, and again when duel tariff was started, so cut the bill by half, but now a large chunk of the bill is the standing charge, and the smart meter and solar software is good at showing how much we use each day, but useless in showing how much at 8.95p per kWh and how much at 31.31p per kWh so it would seem second battery would help reduce export and import at high rate
but not sure if it would save enough to pay for its self? So the 10th when that graph was produced looking on smart meter app, used 8.22 kWh most before 5 am, cost was £1.06 or £1.65 including standing charge.
so looking at that day, a second battery 32½p i.e. cost if all imported was at 8.95p per kWh.
I am sure others have looked at costs, so welcome comments.
.The smart meter was not fitted until January and did not get duel tariff until February, it was noted that solar in Winter would not recharge the battery some days, so all solar produced in winter is in the main used, but money wise it is the recharging of battery over night which saves the most money, this
where battery runs out before the low rate returns is getting more frequent as Winter gets closer, the options on my system is 1 to 4 batteries each battery being 3.2 kWh and the batteries are not cheap, well over £1000 for the battery.We are told batteries have a life, so likely will last 7 to 10 years, but battery one has also given us UPS for freezers and central heating, so no question battery one is well worth it, where it is less cut and dried, is battery two, and our use of electric will change how it helps.
so looking at that day, a second battery 32½p i.e. cost if all imported was at 8.95p per kWh.I am sure others have looked at costs, so welcome comments.
