Outlet for wc flush overflow
8 Jun 2013
Gloucestershire
Can you plumb the 22mm overflow from the cistern back down into wc outlet?
I have, or rather will have, a 38mm pipe running from the adjacent basin into the wc outlet and plan to tap into this rather than coring a hole through the porcelain tile and the wall behind.
I know there is a possibility of smells but in reality, how likely? The S&V pipe is just the other side of the wall and has it's vent to the sky, just a couple of metres above this.
Internal overflow .....https://www.plumbingworld.co.uk/fluidmaster-pro550uk-duel-flush-valve
Let see - it's the main outlet to the soil pipe and for the toilet, where smells would most likely be found ... :unsure:
As suggested, a flush valve with an internal overflow would probably be the best option
Thanks. Had a quick look. Can't work out how it works. Will I be able to fit this to an older, lever-handle cistern? Where does the overflow water go?
The overflow water runs into the tube on the side and runs into the pan,
If you have a manual syphon dual flush valve then you can get replacements with an internal overflow too. if the toilet is close coupled then you will need a new doughnut sepcific for your toilet type too if the flaush valve is to be replaced
