Replacing Shower Tray without Damaging Tiles
7 Mar 2004
My shower tray (Mira Flight Level 1700 X 900 with a waste rated at 30 litres/min) doesn't seem to be able to cope with the water flow from my shower. I think that it's a drain issue as it's never been right - the shower drains just fine at first and then it's as though it clogs up. I presume it's that the drain pipework hasn't got enough of a slope or that the pipework is too small. The shower can run at up to 16 litres/min though it will start to overflow even if adjusted down to 10 litres/min.
I have two options:
1. I could open up the (kitchen) ceiling underneath to access the pipework.
2. I could try and cut out the shower tray but is this even possible with say a multi tool and a great deal of care?
The kitchen ceiling option is obviously going to be very disruptive - I'd prefer not to mess the kitchen up and have to replaster the large ceiling.
Thanks and any ideas? :)
Can you access the point you shower waste connects to the other waste ? Or is it a run on its own
I can't access anything but I think a pair of sinks may be connected to it under the floor somewhere.
Coincidentally (or not), the sinks also have the same issue, as though there's an air lock. They empty at first but tend to fill a little before eventually letting the water drain out.
Usually the issue, not enough fall on the waste.
The kitchen ceiling would be the easiest way TBH but that's only relevant if the waste can be access end to end and re-run properly.
has it struggled from day 1 ?
Sadly, yes. Only discovered it was an issue long after the builders had gone (whole house renovation).
We do notice the odd (very slight) but similar issue occurring in another shower at the other end of the house. The only common denominator (apart from the builder's plumber's likely incompetence - I doubt he was really a plumber) is that we have a septic tank. I did wonder if that was causing an air blockage.
We don't have any issue with the septic tank, though it probably needs emptying anytime now, but occasionally there's a bit of an earthy smell from the shower's drain - never anything "worse" than that though.
From new it would not be unusual for a lazy tiler/plasterer to have put stuff down the drain and its went hard and partially blocked it
I guess there's no way of telling until the ceiling is opened up and the pipework examined - I'll be somewhat irritated if that is the problem ;)
Quick follow-up on this for anyone interested :)
I had a plumber in for a different job and mentioned the shower drainage issue. He had a quick look and removed the blue inserts from the sinks' anti-syphon bottle traps which had been plumbed into the same drain as the shower. So far, so good but McAlpine kindly rang me, talked me through the issue and suggested an alternative - "McAlpine WHB-1 Wash Hand Basin Self Closing Valve" which should allow air in like the anti-syphon trap without the blue plastic sealing washer but will also limit odours from the septic system. If the showers continue to work OK I'll try those out.
