I am thinking of installing two 2 x 6 beams that would support short inspection path above insulation. They would be supported in the middle by 2 x 4 ceiling binder that rests on the inner and outer walls.
The path would be constructed from two 2 x 6 beams about 1.6m long each and would be suspended on internal wall one side (same as the ceiling binder) and on these two new 2 x 6 beams (2m span each) on the other.
I was considering raising the floor from ceiling joists but they are already a bit knackered and ceiling shows signs of cracking in that area hence thinking about other solutions.
My thinking is that it would be enough to support for one person standing on this new path and at the same time do not directly impact ceiling joists.
Is that a bad idea?
Is that a bad idea?
