In 1983 a Potterton Kingfisher floor standing boiler with pilot light and central heating system was installed. It's gravity fed with hot water tank. The radiators have TRV's which don't seem very responsive to temperature changes and the only thermostat in on the boiler and for heating/water there is only a timer system. The boiler on an internal wall and fumes go up a chimney.
Last two times I heated the hot water for a bath it was only luke warm. When recently I checked the radiators on first use since the spring. Radiators heated up ok but after short while I noticed water coming from overflow pipe in loft which was warm. The expansion/feeder tank was hot and the adjactent cold water tank was warm. So no hot water and no heating.
Had a local business come to investigate saying it might be the coils in the hotwater tank, though I don't know what this means. Was informed would need new tank and not sure if they could be one for a gravity fed system with only a pump for the heating system and I would be better replacing the boiler and all the radiators as due to age when they flush the system there may be leaks.
I had been thinking about getting a replacement boiler prior to this but need to know more about what to look for and what questions to ask. There seems to be so many options in boilers, radiators types and sizes. It is a 70 year old detached 3 bed house, 1 bathroom and 1 occupant who does feel the cold now and is spending more time in the house. I am trying to learn so I don't get taken for a ride and get ripped off. Where do I start? I am feeling the pressure with winter coming and no heating and no one to ask. Thanks for reading.
