- Joined
- 10 Nov 2024
- Messages
- 17
- Reaction score
- 8
- Country
Hi everyone,
I have an electric hot water heated unvented cylinder. The reset button keeps popping on the thermostat.
I have tested two screws reading is 14ohm
I took the thermostat out (Tesla) and put it in a tall jar filled with water at a temp of 60 c. I put a meat probe in to get a reference. I then out the Tesla thermostat in and turned the dial untili is clicked (50 C). Leaving it to cool etc it still was between 5 and 10 c out. Could this lag be causing the safety reset to trip?
The thermostat was not fully immersed in the water - there was still some copper at the top, but it was immersed by everything but about 3 inches.
Do you believe this is a thermostat lag that is causing water to get too hot and then trip? or some other reason? Do I need a new thermostat, it is only 2 years old when the stat and the element was replaced together.
If it is a new thermostat, does it have to be the same brand and if not whats your recommendation?
Thanks in advance.
Thanks in advance.
