We must be picturing different things; I know for certain I could hold a Volvo S60 driveshaft in my hands, one hand on the gearbox end splines and one hand on the middle and move my hands apart, stretching the box end CV gaiter and the joint would fall to bits, ball bearings lolling around inside the gaiter. Putting it back together is easy for me now, but chiefly because I stripped the gaiter off and videod the joint coming apart the first time I did it..Absolutely no chance!
Never seen that happen with a 6 ball CV joint. Seen it happen plenty of times with the three pronged tripod type joint though. They just push back in, often without having to remove the cv boot. Was it one of these:We must be picturing different things; I know for certain I could hold a Volvo S60 driveshaft in my hands, one hand on the gearbox end splines and one hand on the middle and move my hands apart, stretching the box end CV gaiter and the joint would fall to bits, ball bearings lolling around inside the gaiter. Putting it back together is easy for me now, but chiefly because I stripped the gaiter off and videod the joint coming apart the first time I did it..
It's easy to make a mistake and pull them too far during the process of getting the shaft off the car, and tricky to get them back together especially if you don't see it come apart
An obvious failure of the CV joint is a split rubber boot ( black grease splattered everywhere) and a clacking noise when turning on full steering lock.
Looking forward to some pics if you can.
John
Completely agree. I just jacked it up and can confirm the outer cv boot both sides is cracked and black grease leaking as people mentioned .
A decent quality cv boot kit will only set you back £20-£25 per side so there's a good saving on £400 if you do it yourself. Plenty of 'how to's' on YouTube for you to follow. £200 per side to fit a CV boot is an absolute pìss take!Completely agree. I just jacked it up and can confirm the outer cv boot both sides is cracked and black grease leaking as people mentioned .
Thanks for all the assistance , as you say - not sure why they didn't just use the correct wording .
Much appreciated all the advice I will look into getting this sorted at a much lower cost than 400 ...hopefully !
Thanks yes been looking at some very good videos - and I would be able to do it ( albeit will take me longer than a lot of people admittedly). I can't see how they justify that amount ...I am finding a lot of garages massively overcharging at least where I am . Not to say all mechanics are on the take but it does disturb me the amount they charge, now I have a much better understanding of what things entail ...it simply doesn't seem fair pricing .A decent quality cv boot kit will only set you back £20-£25 per side so there's a good saving on £400 if you do it yourself. Plenty of 'how to's' on YouTube for you to follow. £200 per side to fit a CV boot is an absolute pìss take!
Thank you I am perusing these options very helpful .there are various kits available to repair; some have a split boot that you glue together with superglue type adhesive, some come with a cone that allows you to carefully stretch the narrow end of the boot (a snug fit on the slender part of the shaft) over the considerably more bulky joint itself, and other kits may need you to remove (if possible, or downsize by disassembly) the joint from the shaft because they won't stretch enough
Personally, I've used the stretch ones after finding the split boot kits a bit lacklustre in terms of longevity; always been amazed that one can get a 5 inch diameter joint through a 1 inch diameter hole in the end of a boot
Was that quote from an Audi dealer or specialist, or independant type garage ?Seems to be a common thing garages massively overcharging at the minute.
Recent mot failure on a 2005 Audi A3 saw me quoted £183 to change front brake pads and £257 quid to change a front wishbone, I did the work myself with the parts coming to £130, there's no way it's £310 worth of labour and they'd of probably got the parts cheaper than me aswell.
