- Joined
- 22 Feb 2022
- Messages
- 109
- Reaction score
- 4
- Country
Hello,
I have a garden log cabin with interlocking timbers - the floor and roof were supplied with insulation I was told but still losing a lot of heat from cold air rising from the flooring.
Currently inside the cabin, the flooring appears to be hard wood and we have put a load of foam interlocking panels across the floor on top of that
Would the insulation kit below be a good solution to help prevent the cold from rising up through the cabin and are there any considerations to think of regarding moisture build up etc.?
www.ecohome-insulation.com
If I get this and then put the foam panels back on top will that be suitable or does it need a membrane or anything?
Hoping it will improve the thermal efficiency of the cabin and keep cold draughts out
EcoTec Floor-Foam Insulation Kit - Concrete Floor Insulation
Effortless insulation for wooden and concrete floors insulation with our EcoTec Floor-Foam Insulation Kit. Simplify installation for an efficient solution.
