Broken neutral even with the light working!?Yes, hence the ...
I haven't actually seen it run because like you say with L and N connected and the light on it should operate until the light is switched off.With a timer fan, if the timed and permanent live feeds are both supplied with power, the fan should operate.
Linking the two terminals simply makes the fan an on/off fan, with no overrun.
If you've proved the fans work (it still may be worth trying with a flex), use a short link wire to join the timed and permanent live connections together.
Then try and connect up the live and switched live in turn (safely isolating power and the other wire when connecting).
If the permanent live is working, the fan should turn constantly.
If the switched live is working, the fan should turn on and off with the switch.
If the fan doesn't work with either - look elsewhere!
The cable to a timer fan would usually be a 3 core + earth; are you sure you've got the grey, brown and black cores marked up correctly?
Wow - nothing trips at all , hows that work ?Builder keeps says maybe fans are too powerful for the circuit
Get one who can , maybe on recommendation from neighbours
i would expect a GOOD builder - at least the ones i have dealt with over the years, and thats probably 4 in the last couple of years, know and use a competent electrician, and as i know a lot about electronics and electrics - as qualified many years ago , i can question and test
any reason why the electrician did not fix it (other than not a good electrician , maybe the sort that do really basic stuff for builder) - or give a plan of what may be required - seems strange , i would expect an electician to work out whats wrong and why, and if he/she cannot - give a number of options on how to resolve , and price
the course of action is to find out why its not working and put it right or at least give a report (maybe verbal) of what needs to be done
yes for a more accurate and reliable machine , FLUKE would be a common make
any pictures
what type of switch in bathroom -
its pretty basic wiring for a fan
Extractor fan wiring - DIYWiki
wiki.diyfaq.org.uk
flamport is also a member here with aa website
Electrical Information Pages
Electrical Information Pages concerning UK electrical installations in domestic and similar situationsflameport.com
i'll edit if i find the info
There were several trips...Wow - nothing trips at all , hows that work ?
I hope your builder is doing a good job on the bathroom itself and just does not understand electrics at all - BUT....... that comment surprised me
OkThere were several trips...
They areThe cables on the right hand side have not been fitted ?
They are
Thanks. Parcel tape is temporary until I get the duct (I have to run around the getting the 1st fix materials for him)Why is he using parcel tape rather than jubilee clamps?
My bad, sorry.
Looks like it needs a switched live-page 13
And no, it is not acceptable to use the earth as a switched live. Get him to pick up some 3 core and earth cable. As a test, bridge the perm/switched live with a small section of cable.
Directly from circuit to light fittingWhere is the extractor fan power supplied from?
Really? I find that unlikely.A lot of fans don’t switch with the LED loads
