Wiring a bathroom extractor fan
9 Feb 2009
Lancashire
Hi all, Im sure this question has been asked before but i cant find a definitive answer.
I am installing a new timed extractor fan in the bathroom.
I want to spur off the light switch to a fused switch for the fan.
The bathroom light switch doesnt have a neutral, so where would i get the neutral from?
Could i buy a single core & earth cable and chop into a cable that comes from the bathroom light in the loft then reconnect the live wire with a double wago connector and then reconnect the neutral wire & earth wire (seperately) using triple wago connector join the new single core & earth cable and run that down to the supply side of the switch?
Hope that makes sense.
Your bathroom light will certainly have a neutral, and a switched live - it might also have a permanent live.
The switch might also have a neutral, it will certainly have a permanent live, and a switched live/switch wire.
You timer fan, will need a neutral, switch wire, and permanent live.
Yeah, i have installed the fan & ran the cable back to the fused switch. It does indeed have neutral, switch wire, and permanent live.
I need to connect the fused switch to the light switch which has permanent live & switched live but no neutral.
So I suppose my question is can i take the neutral from the cable/ceiling rose in the loft and run it back to the supply side of the fused switch.
Although im not sure i can get to the ceiling rose from the loft due to there being a false ceiling, thats why i mentioned chopping into the cable.
Wherever you get the neutral from, then it must be taken from a neutral of the same circuit as you have sourced the live, and switched live. Likely that will be the case, if all your upstairs lighting is on one circuit.
As Harry said the light may have everything you need, so might the switch.
Yep, all upstairs lights are on the same circuit.
It appears I’m good to go. Thanks for the swift replies. If it goes t*ts up I’ll be back.
Cos that’s what the instructions said to install
They aren't always right. Your light circuit will be protected by a 6amp MCB. That is going to trip a long time before a fuse in the "fused switch" blows. So having a fuse is pointless.
I guess you have installed a triple pole fan isolator switch too?
well, it said douple pole fused spur, so i bought one with a switch so i could turn the fan off if the timer function wasnt needed at times like the middle of the night when the wife goes for a pee about 20 times
see above - it was a double pole fused spur the instrucitons said to install
I did see above. Most instructions say that you should (not must) install two switches. the not needed fused switch, which we have discussed, and a 3-pole fan isolator switch.
Like this
