Hi all
I'm in a first floor flat and the shower pressure/flow is pretty poor. At a temp of 40c, the shower flow rate is 7.5 l/min. The cold mains is 8.4 l/min.
I'm thinking about fitting a mains booster pump like this: https://www.salamanderpumps.co.uk/products/mainsbooster/homeboost/ They're not cheap, so I'm trying to figure out if it's going to be worth it, in terms of the increase in flow rate.
My boiler is a 25kw combi, with the following specs:
I have a few questions...
1. The boiler is a glow worm energy 25c (same as vaillant ecofit pure 825). What's this "maximum water flow rate" of 8 l/min listed in the specs?
2. These pumps can supposedly boost the mains supply to 12 l/min. The mains is now 8.4 l /min. That would be a 43% increase.
Currently the cold mains is 7 degrees. Hot water from the boiler is 55 degrees. I'm not a heating engineer, so please forgive any stupid assumptions here, but to get 40c at the shower, that's approx (70% x 55c) + (30% x 7c) = 40.6c. So am I right in saying 70% of the mains flow is going through the boiler?
3. If 70% of the mains flow is going through the boiler, and the mains is boosted to 12 l/min, 70% x 12 = 8.4 l/min being heated by the boiler and going to the shower (before inefficiencies etc so a further 10% may be lost). The ΔT @ 35k is 10.4 l/min for my boiler (eg. 7c --> 42c). So it appears that the boiler has plenty of headroom to heat this extra water?
Following on from that is the main question...if the boiler has the capability to heat the extra water, can I assume this increase of flow through the mains will result in a similar increase in flow to the shower, ie. around 43%?
4. My final concern is that my flat is on the first floor, so water pressure will be lost going up one floor. Will this affect the above figures? That pump says it will boost the pressure to 1.6 bar, but the recommended boiler specs (above) are 2 bar. Will ΔT @ 35k still be 10.4 l/min if the supply pressure is lower than 2 bar?
Jez
Jez
