where did you get your hose from?Just ordered a large 11mm bore shower hose
my shower is a bit piddly as well (not combi just lack of head on cold water tank above shower head)
TIA
I'd say so yeah, a 30% increase is pretty good for 15 quid though!New hose!
Cold (7c)
Flow out of the new hose, no head - 13.5LPM ! (must have some measurement error)
Flow out of the new hose, with head - 12.9LPM
Hot (approx 41c, ΔT = 34c)
Test 1: Flow out of the new hose, no head - 9.6LPM
Test 2: Flow out of the new hose, no head - 10LPM
So...what does this tell us?
1. The new shower hose is a good improvement on the cold
2. The shower head is having little impact
3. My cold water flow rate is fine
My boiler can supposedly produce 10.4LPM, so I guess this is about the best I can hope for then?
Hmm just did some more tests. Temp was around 41c.
Boiler temp set to 56c
Flow out of the new hose, no head - 9.9LPM
Boiler temp set to 60c
Flow out of the new hose, no head - same - 9.9LPM
The increase does seem good for the £££ spent. Although I'm wondering if I calculated the flow rate wrong with the previous hose!
What I'm annoyed about is this boiler is only a year old. Before choosing it, we checked the flow rate on the cold mains at the bath tap, and the kitchen tap. It was around 9LPM. I checked it again today. 8.5LPM out of the kitchen tap. So it didn't make sense to go for a 30kwh boiler at the time. But clearly I should have done! How is it possible that my shower can output over 13LPM on the cold, and the taps only 9LPM at the most.
So next time I need a new boiler...check every outlet in the house!?
