Hi all
For various reasons not worth going over in too much detail I need to install new fence panels along the edge of my garden. There is a step/sharp change in elevation along the way - think two normal bricks tall.
My instinct was to install a fence panel that ends at the step, post at the step, and then fence panel as normal beyond that, but the step is not 'standard fence panel' width away from the side of the house - unless I were to cut a panel to make it less wide which I imagine isn't as simple as it sounds.
My other thought was to cut the corner out of a fence panel. So Post 1 would be before the step, post 2 after it. Panel slots in between them. to allow the panel to hit the floor both sides of the step, I'd cut the corner out of the panel - this would be something like a 50cm x 20cm or so. So imagine a fence panel with a square cut out of the lower left side.
Does this sound sensible or should I approach this in a different way. I've drawn something beautiful in paint to illustrate.
