I’ve recently moved into my mothers very old fashioned house. A lightbulb blew and tripped all the lights upstairs. I went to the fuse box expecting there to be trip switches but there’s not! How can I get the light back on upstairs? Thanks.
I wouldn’t do that, but it would be easier for the OP not having to read the meters.Likewise that old meter, consider having it replaced with a smart meter
However In my experience a fuse blowing has always been perfectly normal when a bulb blows.However, the question is why did the fuse blow? Light bulbs should have built in fuses, which should rupture when the bulb fails with ionisation (the bright flash as a tungsten bulb blows) before it takes out the fuse in the fuse box.
Not as long ago as that HarryRewirable fusewires, have not been installed for maybe 45/50 years.
It has an amazing 40 year certification period from the safety standards people.Meter manufactured 1971 , but may not have been installed that year , have seen thousands older than that .
Yes same here, I added RCD's before the Wylex boxes, and swapped fuses to MCB's, I found renewing fuse wire a fiddly job, and the fuse wire would break as one tightened the screws. There was no plate to stop the fuse wire being pulled by the screw.Our estate was built up until about 1987. They all had rewireable fuse boxes originally
