- Joined
- 12 Feb 2024
- Messages
- 28
- Reaction score
- 0
- Country
Ok this potentially could be my answer , I’ve tried to find some sort of diagram of a system like this but can’t see anything ? Would you mind shedding some light ?You'd setup the boiler's heating connections to an S-plan. That has two (or more) 2-port zone valves to direct the water as required. As a minimum, one zone for heating, one for hot water.
When there is no call for heating, that zone stays off - and the boiler will just run when needed for hot water.
As already pointed out, you really need someone who knows what they're doing - which it sounds like you haven't had so far.
With storage, you decouple demand (hot water out) from supply (boiler output). The boiler keeps the store full, if demand exceeds boiler capacity then the store makes up the difference - for a while.
As said, an unvented cylinder will do the job. Personally I prefer a thermal store which gives mains pressure hot water - and also allows me to run the heating off the store and decouple that from the boiler, while not having a large pressure vessel full of hot water.
Also dumb question but could I not just use the hot water feed from the boiler to fill the thermal store/ cylinder instead of having a cold feed. Or will that go kaboom and then also using the heating side of things with the valves to top up the hot water temp
