Washing line is too tall
22 Nov 2018
I've been busy and no time to put one of the flat's washing lines up. Will I have to take the old pole out and put new one in or is there a quicker solution to cut either the receiving or entering pole down with angle grinder or reciprocating saw?
Pole is too tall
Banging the ground anchor in properly will do the job
By ground anchor u mean pole sticking out the ground? If you mean that I don't think hitting it with a hammer will lower it. Been there ten years in concrete
If the ground anchor won't shift, reduce the height of the pole using an angle grinder and slitting disc.
John :)
Took out this section. Dunno if it's too low now. I measured one elsewhere atc147cm from ground to underside of top when fully extended so maybe should copy that
John :)
Wanna get a dewalt angle grinder, wha j recommend? Something small to start with
I don't have a cordless angle grinder, both of mine are Bosch.
See what Screwfix, Toolstation or Wickes have to offer? Plenty available of the 4 1/2" size.
John :)
Gotta wonder how often you'll use it, if you're a trader and not had to buy one until now then do you really need a Dewalt? Plenty S/H on Marketplace or from the likes of Aldi etc as mentioned. I have Titan, works just fine for occasional use.
I found that after I'd bought my first 4" grinder jobs just kept popping up for it.
I'm a big fan of Lidl/Aldi power tools: amazing value and they have a habit of fitting really long leads.
