- Joined
- 31 May 2020
- Messages
- 312
- Reaction score
- 19
- Country
thanks for your response.Looks the correct head to me, you will need to line up the flats on the spindle (brass bit) with the flats in the actuator. Sometimes moving the actuator manually (plastic lever on the end) helps.
Looking at the flats on the actuator and the spindle, they don’t seem to match up. Am I doing something stupid (most probably )
Are you advising to manually pull the spring whilst on the valve to match up the flats with the spindle?
