Hi. Looking for a bit of help if possible please. Im going to build a block garage at home , Its single skin with 140mm block. I need a lintel for the garage door opening which is going to be 3600 so presume will need a lintel 3900. What type lintel should i use to span this length ? There wont be much load on it just 2 courses of 140mm block above. The roof sits on a separate steel frame. Any advice much appreciated
