Hi All.
I have a heat-only gas boiler downstairs (pump is upstairs) with a Megaflo Tank upstairs that has a red expansion tank and pressure gauge above it. The expansion tank is about 12 inches (30cm) tall and 9 inches (22.5cm) wide.
The gauge has a red line set at 1 bar which, rightly or wrongly, I take as a setting point for the pressure. Every month or two I notice that the pressure drops gradually to around 0.75 bar. At this point I open the little tap for a few seconds and top the tank up until the gauge reads just under 1 bar. I have been doing this for somewhere approaching 20 years.
Several years ago a BG engineer (I have a maintenance contract with them) said I shouldn't be touching anything and he used a foot pump to pump some air in but it never solved the issue so I kept topping-up as required.
I have a few questions.
1. There has never been any visible leaks in the CH/HW system so where all the water is going?
2. I had a new boiler several years ago and that was the last time inhibitor was put in the system. Should I have some more added as I must be diluting it every time I top-up?
3. Am I doing the right thing by topping-up every now and again or is there a fault in my system that can be remedied so the pressure doesn't drop so much?
Any explanations or advice would be much appreciated.
Thanks in advance.
Thanks in advance.
