DCV and Anti-Siphon WC inlet
15 Feb 2008
Hi there - I’m about to fit a new inlet valve to bottom entry cistern.
I’ll be using a FLUIDMASTER 400 Bottom Entry Fill Valve – 1/2″ Brass Shank.
I’ve used these before - this is third one I’ve fitted (for myself) and I quite like them.
It says ‘Anti-siphon design prevents contamination of water supply’.
Does that mean it won’t need a DCV on supply line ?
Thanks D
What do the instructions state? Probably best checking with WRAS if you’re unsure.
If my memory serves me well, the valve has been designed so that when not under positive pressure, the supply side is open to the atmosphere and therefore syphoning cannot occur. Once the pressure is applied, that route is closed. I have one in all three WWP's in my house and all function as they were designed to.
Thank you for the link to helpful WRAS Certification Statement; that clearly states I should have a DCV (irrespective of the built in anti-siphon).
This is likely a silly question - an air gap / AUK1 on a cistern; I’m guessing with a bottom fill I don’t have one but how do I know ?
Thanks D
The clue's in the description, if it's a bottom fill it means it fills from the bottom of the valve, therefore there will always be a situation where the mains water could be in contact with the cistern water, hence the requirement for a DCV. Other fill valves, where there is a visible gap between where the water comes out of the valve and the finished fill level are valves that incorporates an air gap and a DCV isn't required. This should be at least 20mm above the finished fill level or twice the (edit) pipe size filling it - (15mm pipe x 2 = 30mm)
Some of the newer UK Fluidmaster valves provide that air gap, I have gone from the Black Pro bottom fill valves to these now, where space in the cistern allows
Everyday is a school day - I’d no idea on that as an option. I just went for the type (400 series) I’d previously fitted. I’ll have a look at available space in cistern. Failing that, I’ll fit the DCV.
Thanks for clarifying the regs and the heads up to the Air-Gap variant.
Best D
It doesn't actually take up that much more space, if you see what I mean, as the float is quite high up but if the cistern has a syphon flush valve then the wide shape of the syphon can get in the way, if the cistern doesn't have enough space to the right
